TwinTurbo.NET: Nissan 300ZX forum - Are they stock?
Are they stock?
ZiNnYc
on February 05, 2011 at 4:40 PM
how do i check if the oil lines are clogged? (n/m)
posted by supersh0cker
on February 04, 2011 at 09:42 AM
I would honestly replace them with some SS lines...not sure how doable it is with the engine in, maybe someone else can chime in.
30 degrees out side and passenger turbo squeeling
supersh0cker
20:46:59 02/02/11
If it's seized you'll see zero boost. A squeal only when...
Ted (92TT)
21:06:04 02/02/11
thnx, in first gear for a while it would only get 0psi
supersh0cker
21:11:40 02/02/11
IMO, no harm in driving except it may kill the catalyst...
Ted (92TT)
22:06:33 02/02/11
i have z1 downpipes and no cats, so no worries, how hard is
supersh0cker
22:18:52 02/02/11
Passenger side DP is pretty easy to remove...
Ted (92TT)
23:33:38 02/02/11
I wouldn't say even *you doing it was a good idea.
CoHPhasor
03:48:24 02/03/11
Good point. (n/m)
Ted (92TT)
11:14:49 02/03/11
how would i check if im not getting oil to the shaft?
supersh0cker
22:00:51 02/02/11
anyone taken of the PS turbo? i read that i have to take off
supersh0cker
10:32:15 02/03/11
I've done it with the tranny in the car. (n/m)
Woody75 (Denver)
11:50:13 02/03/11
thnx, any tool that would make it easier? (n/m)
supersh0cker
11:57:58 02/03/11
Curved box end wreches came in handy. (n/m)
Woody75 (Denver)
09:34:07 02/04/11
got under the car and found the oil return was leaking from
supersh0cker
13:56:44 02/03/11
Re: got under the car and found the oil return was leaking from
aliaZ
15:19:20 02/03/11
got back from drive, turbo doing the same thing
supersh0cker
15:34:07 02/03/11
have you checked for boost leaks? (n/m)
aliaZ
21:58:09 02/03/11
i have not checked for boost leaks yet i didnt think about
supersh0cker
09:41:17 02/04/11
Make sure its the turbo squealing, not something else.
ZiNnYc
07:37:48 02/04/11
supersh0cker
09:42:10 02/04/11
Are they stock? -
ZiNnYc
16:40:25 02/05/11
